Zipflex install issue http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50802 |
Author: | SnowManSnow [ Mon Jul 09, 2018 6:21 pm ] |
Post subject: | Zipflex install issue |
I realize not everyone is a fan of zipflex. However I’m using it as n the parameter of my 000 build. I have a slight issue because the width is ~.010 too wide. The extra width is the rubber substrate around it. I have used the smallest bearing to cut the channel I have. The plan is to install the zipflex and the BWB in the same channel, but with. The extra width it causes the wood binding which would come next to lean out, which is obviously unacceptable. My thoughts on a course of action is to: 1: install as is 2: carefully sand away the outer rubber and enough of the pearl sonthat it sits flush with where it needs to be 3: install binding as planned. Am I asking for trouble like this ? Advise is appreciated B Sent from my iPhone using Tapatalk Pro |
Author: | Freeman [ Mon Jul 09, 2018 6:24 pm ] |
Post subject: | Re: Zipflex install issue |
Why not get the right size bearing and make the channel the right size? Then you'll have that bearing for the next time |
Author: | SnowManSnow [ Mon Jul 09, 2018 6:36 pm ] |
Freeman wrote: Why not get the right size bearing and make the channel the right size? Then you'll have that bearing for the next time I’m looking for it Sent from my iPhone using Tapatalk Pro |
Author: | meddlingfool [ Mon Jul 09, 2018 6:40 pm ] |
Have you checked LMI? |
Author: | Freeman [ Mon Jul 09, 2018 6:50 pm ] |
https://www.stewmac.com/Luthier_Tools/T ... rings.html |
Author: | SnowManSnow [ Mon Jul 09, 2018 6:52 pm ] |
I found it:/ sorry for the panic Post guys Sent from my iPhone using Tapatalk Pro |
Author: | SnowManSnow [ Mon Jul 09, 2018 7:02 pm ] |
On a related issue... a friend of mine recommended using a gramil before cutting any channels... do you all use one ? Sent from my iPhone using Tapatalk Pro |
Author: | johnparchem [ Mon Jul 09, 2018 7:55 pm ] |
SnowManSnow wrote: On a related issue... a friend of mine recommended using a gramil before cutting any channels... do you all use one ? Sent from my iPhone using Tapatalk Pro Before you found the bearing I was going to suggest a gramil to widen the channel. |
Author: | meddlingfool [ Mon Jul 09, 2018 8:40 pm ] |
Nope. |
Author: | Jim Watts [ Mon Jul 09, 2018 11:18 pm ] |
SnowManSnow wrote: On a related issue... a friend of mine recommended using a gramil before cutting any channels... do you all use one ? Sent from my iPhone using Tapatalk Pro It's obviously not necessary but I always do this on tops. It eliminates the fuzzy's and makes for really clean cuts. Another tip is to apply a wash coat of shellac to the top, this helps too. |
Author: | ernie [ Tue Jul 10, 2018 8:27 am ] |
I have 2 purfling /binding cutters one is brass and cherry for guitar making and the other is an all brass chinese vln purfling cutter. On some tops and backs especially with irregular grain . I like to pre score my binding /purfling line. |
Author: | Joe Beaver [ Sun Jul 15, 2018 5:41 pm ] |
Glad to hear you have found a resolution. I like to do all kinds of odd binding schemes and also struggled to cut the right size channels with the cutters that use the bearings for a guide. Plus my cutter for the set developed a crack, so I bit the bullet and bought the setup from Luthiers Suppliers , I think it was. |
